Selectively disables SNMP access on virtual routers.
| vr_name | Specifies the virtual router name. |
| all | Specifies all virtual routers. |
Enabled on all virtual routers.
Use this command to disable SNMP access on any or all virtual routers.
When SNMP access is disabled on a virtual router, the incoming SNMP request is dropped and an EMS message is logged.
To enable SNMP access on virtual routers use the enable snmp access vr command.
To display the SNMP configuration and statistics on a specified virtual router, use the show snmp vr_name command.
The following command disables SNMP access on the virtual router vr-finance:
disable snmp access vr vr-finance
This command was first available in ExtremeXOS 12.4.2.
